Artlav
Full Member level 2
Are there any practical ways of getting mains-style 220V AC from a source giving between 1 and 2 volts?
The source can provide hundreds of amps, the output power level needs to be around 10 to 50W.
Only non-exotic idea i have is to use some sort of low power boost/charge pump IC to provide higher voltage to power the logic and MOSFET gates, then build a more or less the usual inverter.
