spacefighter
Newbie level 2
- Joined
- Mar 28, 2014
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 26
Hi
I am trying to extend the range of a garage door remote transmitter. It is one of the older styles with the dip switch on the back to key in the code, 300 MHz analog. I don’t know enough about RF so I came for help.
So far after checking out the circuit I added an external antenna off the single coil. This has helped quite a bit but still not where I want it. I am getting about 20 feet where before I almost had to hold it to the door.
I believe the biggest problem is that it’s for a metal building, I am sure this is shielding a lot of the signal. I am hoping I could overcome this with more power :twisted: which probably isn’t the way to fix it.
Can I build some sort of amplifier to boost the power? Or perhaps build a stronger transmitter circuit.
Any ideas would be helpful
Thanks!!
Thanks!!
