amitaiwe
Member level 3
- Joined
- Feb 19, 2014
- Messages
- 57
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 547
I'm trying to wire up a BT module RN42SM.
I have a battery of 9V and the recommended vin is 3.3v.
I tried using a Voltage divider and it turned out that the BT has a very
high resistance and for various values of resistor the voltage input to
the BT was epx. 1.5V.
only when I connected directly the 9V the BT turned on (led)
and became hot very quickly..
Is there a way of using the battery to connect to the BT without
ruining it? do I need to use some digital supply instead?
Thanks, Amitai
Thanks, Amitai
