Mar 3, 2014 #1 microcon555 Advanced Member level 4 Joined Feb 13, 2009 Messages 108 Helped 9 Reputation 18 Reaction score 6 Trophy points 1,298 Activity points 1,877 Hi I cant find any tutorial / example for setup sequence of bluetooth module to microcontroller I am using HC05 bluetooth module. MicroCon
Mar 3, 2014 #2 xpress_embedo Advanced Member level 4 Joined Jul 5, 2011 Messages 1,154 Helped 161 Reputation 396 Reaction score 189 Trophy points 1,353 Location India Activity points 10,591 There is nothing to setup. Just connect HC05 with UART of Micro-Controller and it will transmit and receive normally. When searching bluetooth you will find HC05 Bluetooth device and by default password is 1234 For changing the default settings there are few at command like at+baud, at+name, at+pin have a look at this link also https://www.instructables.com/id/Modify-The-HC-05-Bluetooth-Module-Defaults-Using-A/
