blinking led
sumit garg
Junior Member level 1
i want to make circuit in which some leds should blink at some frequency. i found lot of circuits on internet source and tried to do their simulation in proteus, but nothing is working .can you suggest any better idea.
Thanks...
my hints:
Don´t use random circuits from random hobbyists. Many of them are of bad quality (not all of them). Often the informations are incomplete or even wrong.
(The given schematics show that they are not drawn by professionals, because they violate the simplest rules for schematics, like: Signal flow (information flow) from left to right. Positive supply on top, negative supply on bottom, and using symbols for supplies (like GND symbols). Such schematics are as hard to read as a backwards written text ).
Better use tutorials provided by schools, universities, semiconductor manufacturers or similar.
Also use videos from above sources ... best if they use tools and software you are familiar with.
Don´t be afraid of "too much information". It´s better to understand only 70% ... instead of missing the one important information you need.
Klaus
my hints:
Klaus
but i have no other option than internet source ,can you suggest me how do ican make a circuit for blinking leds
I talked about internet sources...
The internet provides a lot of good informations. I told you how to select the good from the bad.
When I do a search for "blinking LED schematic" there show up 5 million hits. Even if 99% are bad .. there are 50 thousand good ones. No need for a 50,001 one.
If you do a search for "blinking LED tutorial" there come a lot of arduino hits,
If you want to exclude Arduino, the just do a search for "blinking LED tutorial -arduino".
If you want to focus on BJT circuits then do a search for "blinking LED BJT tutorial".
... Now about 50 thousand hits with 5 thousand videos.
--> Improve your search skills. All information is available.
Klaus
Some circuits with LEDs in them :
See attached as well.
Regards, Dana.
--- Updated ---
1) Can you write program in any computer language ?
2) You going to build circuit or just simulate ?
3) What specifically do you want led(s) to do ?
Regards, Dana.
  • Sundry-Timers-555TimerApplicationsOCR.pdf
  • el timer 555.pdf
  • Forrest Mims - Optoelectronics Circuits.pdf
  • Using The “555” Timer IC In ‘Special’ Or Unusual Circuits _ Nuts & Volts Magazine.pdf
Hi.
Read some more about LEDs and circuits before building what you see on the web. Do you have a specific voltage supply you want to use ? Do you want a color or many ? Do you want a fixed rate, a variable rate, one or many LEDs ? Do you know that flashing is another word for your search, yielding another million results ? Do you know that self-flashing LEDs of many flavors are available ?
----> https://www.ecosia.org/images?q=led flasher circuit
----> https://www.ebay.com/itm/1221001769...hOeKorvVjK0nIQlaBq80nT4/6i|tkp:Bk9SR4yNx4rcYA
