blink led program in c18 compiler
hemnath
Advanced Member level 3
Chennai
Hi, I'm using c18 compiler, 18F8722 microcontroller, cystal 20Mhz.
HTML:
#include<p18f8722.h>
#pragma config  OSC = HS, IESO = OFF, FCMEN = OFF, WDT = OFF
/*  ***************  TIMER *************** */
void delayzz(void)
	int i, j;
	for(i=0;i<1000;i++)
		for(j=0;j<2;j++)
			  /* Well its Just a Timer */
                /* ****************** MAIN ****************** */
void main(void)
	TRISD= 0x00;                  // PORT B Setting: Set all the pins in port B to Output.
	while(1)
		LATDbits.LATD0 = 1;   // RB-1 to High
		Delay10KTCYx(250);
//		delayzz();
		LATDbits.LATD0 = 0;    // RB-0 to LOW
		Delay10KTCYx(250);
//		delayzz();
Trying to blink the led which is conneced on pin D0. But it is not blinking. What could be the problem?
Please help.
What is happening ? Does the LED turn ON but not OFF ? Maybe delays are not proper.
It is not at all blinking. When I changed the configuration settings to IESO = ON. It is blinking.
I thought that crystal 20Mhz could be damaged. But already i have changed it to new crystal also.
HTML:
void main(void)
	TRISD= 0x00;
	while(1)
Very simple code to glow the LED. It is not working with configuration settings IESO = OFF. LED glows once i changed to IESO = ON
But i want to use the external oscillator. Please find the zip file.
  • Blink LED.zip
Proves that the external oscillator is not working. This is a hardware rather than a coding problem.
By the way, why are you always using HTML code tags for C code?
Are you testing on breadboard ? If yes, try on a soldered board or atleast solder the oscillator circuit and try.
I'm not testing on breadboard. I have a development board. Since there could be a chance of bad crystal. So i have replaced it with new 20Mhz crystal and 22pf capacitors. I have also double checked the connections from oscillator to micro-controller pins.
But still led doesn't turn ON.
