georgeg
I came across some hobbyists and they told me that, they would rather go for multi layers or micro vias than burried vias? Why is that? I also heard it is more expensive to make blind and burried vias. Why? Just curious...
Once I tried to make a 4-layer design with blind vias from layer 2 to layer 4. The manufacturer told me it was not possible to do this kind of via with the stack setup I needed.
Why is that so? How can I know which are the layers I can (or can't) connect with blind/buried vias?
I think maybe you were up against a limitation of the PCB mfr. There is no fundamental reason you CAN"T do what you want. But, unless you REALLY have a shortage of real-estate on your board, blind and buried vias aren't necessary. For a four layer board, I can't believe you've got this problem. If you were working with an 8 layer or more board, then it might be an issue.
