Vamsi:
Thanks for your response for my inquiry. I am somewhat familiar with the process you said. can you elaborate more?
here are some of the things im not really sure.
if ever i had a stack up of TOP,GND,INT1,INT2,VCC,BOT
1.) if i want a blind via from TOP to GND. will i set INT1, INT2, VCC & BOT as No Connect? just like from what I attached? [/img]
2.) if i want a buried via from INT1 to INT2. will i set TOP, GND, VCC & BOT as No Connect? just like fromt what I attached?
3.)when exporting N/C Drill. will i separate N/C Drill for every kind of blind and buried via? example: 1 N/C Drill for blind via from TOP to GND, 1 N/C Drill for blind via from BOT to VCC, 1 N/C Drill for buried via from INT1 to INT2 etc....
4.) how will i create a drill table located on the fabrication notes? will i separate it just like #3 or just 1 drill table.
Thank you very much.
