ashugtiwari
Full Member level 4
- Joined
- Dec 12, 2008
- Messages
- 218
- Helped
- 45
- Reputation
- 90
- Reaction score
- 44
- Trophy points
- 1,308
- Activity points
- 3,310
Hi All,
Im using small ebmpast 24V small BLDC motor to write test code for motor speed control.
I found that controlling the commutation speed affects the motor speed as well (well thats obvious). So, my question is, when i change the PWM duty cycle, the speed does not change at all but speed is solely controlled by commutation speed.
is PWM only used to reduce the I2R losses in motor coil or it actually controls the speed? In my case, PWM when decreased slowly from 100%, the speed does not change (decrease) but after certain minimum duty cycle (below some lower threshold), motor stops.
I read so many articles online for BLDC motor control buti could not understand why this happens. (im not so smart :roll
Thanks
Ashutosh
Thanks
Ashutosh
