#define Ccu6_SetPtns(CURHS, EXPHS, MCMPS) \
( (((uint32)(MCMPS)) << 0u) | \
(((uint32)(EXPHS)) << 8u) | \
(((uint32)(CURHS)) << 11U ) )
const TEmoCcu_Cfg EmoCcu_Cfg =
/* HallOutPtns[16] - Hall and output patterns
* Value = f(current Hall pattern, expected Hall pattern, output pattern)
#if (BCHALL_OFFSET_60DEGREE_EN == 0)
(uint16)Ccu6_SetPtns(0, 0, 0x00), /* Hall pattern=0, forward direction (error) */
(uint16)Ccu6_SetPtns(1, 3, 0x31), /* Hall pattern=1, forward direction */
(uint16)Ccu6_SetPtns(2, 6, 0x07), /* Hall pattern=2, forward direction */
(uint16)Ccu6_SetPtns(3, 2, 0x34), /* Hall pattern=3, forward direction */
(uint16)Ccu6_SetPtns(4, 5, 0x1C), /* Hall pattern=4, forward direction */
(uint16)Ccu6_SetPtns(5, 1, 0x0D), /* Hall pattern=5, forward direction */
(uint16)Ccu6_SetPtns(6, 4, 0x13), /* Hall pattern=6, forward direction */
(uint16)Ccu6_SetPtns(0, 0, 0x00), /* Hall pattern=7, forward direction (error) */
(uint16)Ccu6_SetPtns(0, 0, 0x00), /* Hall pattern=0, reverse direction (error) */
(uint16)Ccu6_SetPtns(1, 5, 0x13), /* Hall pattern=1, reverse direction */
(uint16)Ccu6_SetPtns(2, 3, 0x0D), /* Hall pattern=2, reverse direction */
(uint16)Ccu6_SetPtns(3, 1, 0x1C), /* Hall pattern=3, reverse direction */
(uint16)Ccu6_SetPtns(4, 6, 0x34), /* Hall pattern=4, reverse direction */
(uint16)Ccu6_SetPtns(5, 4, 0x07), /* Hall pattern=5, reverse direction */
(uint16)Ccu6_SetPtns(6, 2, 0x31), /* Hall pattern=6, reverse direction */
(uint16)Ccu6_SetPtns(0, 0, 0x00) /* Hall pattern=7, reverse direction (error) */
#else /* (BCHALL_OFFSET_60DEGREE_EN == 1) */
(uint16)Ccu6_SetPtns(1, 3, 0x0D), /* Hall pattern=1, forward direction */
(uint16)Ccu6_SetPtns(2, 6, 0x34), /* Hall pattern=2, forward direction */
(uint16)Ccu6_SetPtns(3, 2, 0x31), /* Hall pattern=3, forward direction */
(uint16)Ccu6_SetPtns(4, 5, 0x13), /* Hall pattern=4, forward direction */
(uint16)Ccu6_SetPtns(5, 1, 0x1C), /* Hall pattern=5, forward direction */
(uint16)Ccu6_SetPtns(6, 4, 0x07), /* Hall pattern=6, forward direction */
(uint16)Ccu6_SetPtns(1, 5, 0x07), /* Hall pattern=1, reverse direction */
(uint16)Ccu6_SetPtns(2, 3, 0x1C), /* Hall pattern=2, reverse direction */
(uint16)Ccu6_SetPtns(3, 1, 0x13), /* Hall pattern=3, reverse direction */
(uint16)Ccu6_SetPtns(4, 6, 0x31), /* Hall pattern=4, reverse direction */
(uint16)Ccu6_SetPtns(5, 4, 0x34), /* Hall pattern=5, reverse direction */
(uint16)Ccu6_SetPtns(6, 2, 0x0D), /* Hall pattern=6, reverse direction */
#endif /* (BCHALL_OFFSET_60DEGREE_EN == 1) */
/* T12Moden - T12 modulation enable patterns
* Table value = 0x80(MCMEN) + pattern for T12MODEN
* Pattern = COUT62*32 + CC62*16 + COUT61*8 + CC61*4 + COUT60*2 + CC60 */
(uint8)(0x00), /* Hall pattern=0, forward direction (error) */
(uint8)(0x80 + 0x33), /* Hall pattern=1, forward direction */
(uint8)(0x80 + 0x3C), /* Hall pattern=2, forward direction */
(uint8)(0x80 + 0x0F), /* Hall pattern=3, forward direction */
(uint8)(0x80 + 0x3C), /* Hall pattern=4, forward direction */
(uint8)(0x80 + 0x30), /* Hall pattern=5, forward direction */
(uint8)(0x80 + 0x0F), /* Hall pattern=6, forward direction */
(uint8)(0x00), /* Hall pattern=7, forward direction (error) */
(uint8)(0x00), /* Hall pattern=0, reverse direction (error) */
(uint8)(0x80 + 0x03), /* Hall pattern=1, reverse direction */
(uint8)(0x80 + 0x0C), /* Hall pattern=2, reverse direction */
(uint8)(0x80 + 0x0F), /* Hall pattern=3, reverse direction */
(uint8)(0x80 + 0x30), /* Hall pattern=4, reverse direction */
(uint8)(0x80 + 0x33), /* Hall pattern=5, reverse direction */
(uint8)(0x80 + 0x3C), /* Hall pattern=6, reverse direction */
(uint8)(0x00) /* Hall pattern=7, reverse direction (error) */
(uint8)(0x80 + 0x3C), /* Hall pattern=1, forward direction */
(uint8)(0x80 + 0x33), /* Hall pattern=2, forward direction */
(uint8)(0x80 + 0x30), /* Hall pattern=3, forward direction */
(uint8)(0x80 + 0x0F), /* Hall pattern=4, forward direction */
(uint8)(0x80 + 0x0C), /* Hall pattern=5, forward direction */
(uint8)(0x80 + 0x03), /* Hall pattern=6, forward direction */
(uint8)(0x80 + 0x33), /* Hall pattern=1, reverse direction */
(uint8)(0x80 + 0x0F), /* Hall pattern=2, reverse direction */
(uint8)(0x80 + 0x03), /* Hall pattern=3, reverse direction */
(uint8)(0x80 + 0x3C), /* Hall pattern=4, reverse direction */
(uint8)(0x80 + 0x30), /* Hall pattern=5, reverse direction */
(uint8)(0x80 + 0x0C), /* Hall pattern=6, reverse direction */
