Bitstream generation after some change of VHDL code
BlackOps
Full Member level 5
AZERBAIJAN
Hello, i am using EDK 9.1
I have added standard peripheral using wizard. Then for example i want to add some changes to the VHDL code of the peripheral.. but if i want to generate bitstream again, it takes again a lot of time...even after some little change in VHDL...
is there a way of not generating the whole VHDL code....but rather to re-generate the part which changed? i hope u understand me... cuz it takes lot of time
thanks
You can't help it buddy. Even a single line of code change (in a single file!) required re-run of synthesis, implementation(translate, map, p&r) & programming file generation steps all over again.
You can upgrade your workstation's processor or increase the RAM. This might finish the activities faster :|
