Captain_Mainwaring
Newbie level 5
Hi all,
I have a need for a circuit and thought I would post it onto this forum for some guidance. I have existing circuitry for a scale consisting of a strain gauge, wheatstone bridge and OPA333 op-amp. (I am stuck with this circuit so have to work with it).
I have fed the output of this op-amp into my ADC/microcontroller but the results aren't great, the main issue is with the signal out of the OPA333. (pls see attachment)
When the scales are unloaded the signal level is 0.95v. When loaded the signal level is typically around 1.3v with +/- 0.1v fluctuations for movement (actual levels depending on the animal being weighed and how much they can shift their weight about (the fluctuations)). I need to record the stationary loaded weight and also the variations due to the animal moving around.
However, the issue is with the poor use of range, I am using less than 10% of the signal range (and thus of the ADC range) and about 3% of the signal range for the fluctuations for movement. What I need to do is remove the 0.95v offset, then amplify to make sensible use of the ADC range. eg.
What is the best way to remove a DC offset in a DC signal? An op-amp Comparator?
I would then plan to use a non-inverting op-amp to amplify, is this the best way?
All/any opinions are warmly received.
Ta,
George
Ta,
George
