sanket.joshi
Member level 3
- Joined
- Jun 27, 2013
- Messages
- 65
- Helped
- 8
- Reputation
- 16
- Reaction score
- 8
- Trophy points
- 8
- Location
- Mumbai,India
- Activity points
- 386
i want to interface RF-ID module using any two pins of 8051...
i have written following code...
since RF-ID only transmit data i have written code for receiving...
but i m getting nothing on the LCD except statement(CARD ID..
what is the mistake in this program?
kindly help me...
its urgent friends...please help me
include<reg51f.h>
#include<string.h>
#define _XTAL_FREQ 11059200
#define Baudrate 9600
#define OneBitDelay (100000000/Baudrate)
#define port P0
#define lcdport P1 //14,13,12,11 pins of lcd and 1.7,1.6,1.5,1.4 of controller
sbit rs=port^0; //Register select
sbit rw=port^1; //Read/Write
sbit en=port^2; //Enable pin
sbit UART_RX=P2^0;
sbit UART_TX=P2^1;
unsigned char d[12]=0,i,l;
unsigned char card_id[12];
void delay(unsigned int count) //Function to provide delay
int i,j;
for(i=0;i<count;i++)
for(j=0;j<1100;j++);
void lcdcmd(char cmdout)
lcdport=cmdout;
rs=0;
rw=0;
en=1;
delay(10);
en=0;
void lcddata(char dataout)
lcdport=dataout;
rs=1;
rw=0;
en=1;
delay(10);
en=0;
void dis_cmd(char cmd_value)
char cmd_value1;
cmd_value1 = cmd_value & 0xF0; //mask lower nibble because PA4-PA7 pins are used.
lcdcmd(cmd_value1); // send to LCD
cmd_value1 = ((cmd_value<<4) & 0xF0); //shift 4-bit and mask
void dis_data(char data_value)
char data_value1;
data_value1=data_value&0xF0;
lcddata(data_value1);
data_value1=((data_value<<4)&0xF0);
void __delay_us(unsigned int d)
unsigned int i, limit;
limit = d/15;
for(i=0;i<limit;i++);
void lcd_init() // fuction for intialize
dis_cmd(0x02); // to initialize LCD in 4-bit mode.
dis_cmd(0x28); //to initialize LCD in 2 lines, 5X7 dots and 4bit mode.
dis_cmd(0x0C);
dis_cmd(0x06);
dis_cmd(0x80);
void initialize_serialcommunication(void)
SCON = 0x50;
TMOD = 0x20;
TH1 = 0xFD;
TL1 = 0xFD;
TR1 = 1;
TI = 1;
void init(void)
UART_RX = 1; //set as i/p
UART_TX = 0; //set as o/p
unsigned char receive(void)
unsigned char DataValue = 0,i;
//wait for start bit
while(UART_RX==1);
__delay_us(OneBitDelay);
__delay_us(OneBitDelay/2); // Take sample value in the mid of bit duration
for ( i = 0; i < 8; i++ )
if ( UART_RX == 1 ) //if received bit is high
DataValue += (1<<i);
// Check for stop bit
if ( UART_RX == 1 ) //Stop bit should be high
return DataValue;
else //some error occurred !
return 0x000;
void rfid_data(void)
for(i=0;i<12;i++)
card_id[i]=receive();
void main(void)
//unsigned char ch;
unsigned char data0[]="CARD ID:";
lcdport=0;
init();
//initialize_serialcommunication();
lcd_init();
dis_cmd(0x81); //Place cursor to second position of first line
while(data0[i]!='\0')
dis_data(data0[i]);
delay(20);
i++;
while(1)
rfid_data();
dis_cmd(0xC1); //Place cursor to second position of second line
for(l=0;l<12;l++)
dis_data(card_id[l]);
delay(20);
kindly help me...
