Binary Design Algorithm - a binary Input/Output
OMID-313
Junior Member level 2
Solar System
Hi everyone
I want to design a binary Input/Output :
Input : x = an 8-bit binary number ( positive integer )
Output : √x = an 8-bit binary number : the bits from 5 to 8 form the integer part , and the bits from 1 to 4 form the decimal part.
Please help me design the algorithm of this project.
Thanks !!
It may not be not what you want, but a lookup-table would be fastest and simplest.
do you want to write it in asembler or C? If its C then you can just write your function in 2 or 3 lines. If you want it in asembler be prepared to spend a while on it. It can be done but you would have to get sum1 who is either really bored or has a lot of time on his hands or both to help you.
