jhanus
Member level 2
Hello,
let me get directly to the point, I'm developing a project in assembler.
But I got to a wall, the problem is that I got carried away a bit, and my program size exponentially increased.
So after researching I assumed the problem is when I use 'call' trough more then 255 instructions, because while testing in Proteus it gave me underflow and overflow errors.
To eliminate this problem I disabled some functions and it worked.
After more reading I found potential solution trough division of code to pages and using PCLATH.
Then, while cruising trough datasheet of PIC 16F628a I saw 2048word limit for program(I never got a problem with program size before!) and my HEX file has 2,57 KB (2.637 bytes)...
After that I realized that my previous hex file for 16f84a had 1,97 KB (2.019 bytes) and it worked fine.(16f84a has 1024words)
So, my question is how is this possible?!
EDIT: I 'discovered' the problem with program size, but my errors with underflow and overflow stay
