bouvett
Newbie level 2
hi i am currently working on a project which involves interfacing an fpga with a glcd. now i need the port that connects the fpga to the glcd datapins to be bi directional. I have already wrote the code:
and it works well when connected on its own, ie itself being the top module. But in my project i need this module to be just one of other submodules and then connect them as a whole in one top level.
When i connect it in a toplevel, i connect the GLCD_PINS shown above, with the top level port, also an inout type using an std_logic_vector.
i do this by writing
glcd <= GLCD_PINS;
now when i write it this way, the system only allows writes from the submodule. when i write
GLCD_PINS <= glcd
the system only allows reads.
What can i do to solve this problem please? I am really confused about this thing :/
thanks for the help.
regards,
Emmanuel Bouvett
entity GLCD_BI_DIRECTIONAL_PORT is
Port ( GLCD_DATA_WRITE : in STD_LOGIC_VECTOR (3 downto 0);
GLCD_DATA_READ : OUT STD_LOGIC_VECTOR (3 downto 0);
CONTROL : in STD_LOGIC;
GLCD_PINS : inout STD_LOGIC_VECTOR (3 downto 0));
end GLCD_BI_DIRECTIONAL_PORT;
architecture Behavioral of GLCD_BI_DIRECTIONAL_PORT is
begin
PROCESS(CONTROL,GLCD_DATA_WRITE,GLCD_PINS)
BEGIN
IF(CONTROL = '0') THEN -- WRITE
GLCD_PINS <= GLCD_DATA_WRITE;
ELSE
GLCD_PINS <= "ZZZZ"; -- SET AS HIGH IMPEDANCE INPUT
GLCD_DATA_READ <= GLCD_PINS;
END IF;
END PROCESS;
end Behavioral;
glcd <= GLCD_PINS;
GLCD_PINS <= glcd
regards,
Emmanuel Bouvett
