LvW
Advanced Member level 6
My mean is , why we should involve ourselves with some definitions ?
For example , when we have two voltage divider resistors as base bias resistors . be can easily consider , VB is given by a simple divide between two resistors ! but the fact is we can't do it because of base current ! but because base current is negligible , we can do it !!
Just one comment:
The classical procedure for designing the voltage divider for base biasing is to select a current through the upper resistor that is (n+1)-times larger than the anticipated base current - with the result that a current n*Ib flows through the lower base resistor. And this approach gives us formulas for both resistors.
Thus, of course it is possible (and it is normally done) NOT to neglect the base current during this design step.
However, this does not mean the base current would assume any control functions.
