mburakbaran
Member level 2
- Joined
- Jan 18, 2010
- Messages
- 44
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- leuven
- Activity points
- 1,724
Hello,
I'm working on EMI-robust digital drivers. I have a push pull output. I'd like to protect my output transistors in case a negative voltage appears on output (NMOS is in danger, body diode turns on an excessive current flowa) and in case a more than supply voltage appears on the output (this time PMOS is in danger).
I was thinking maybe biasing these diodes beforehand could help turning on them sooner before the body diodes does. In the schematic, for example 0.7V bias for the anode of D1 and 4.3V bias for the cathode of D2 seems to be helping a lot in case of an excessive EMI injection. Everything seems fine when I use VDC from cadence for the biases but I was wondering how to realize this. I must also mention that I need a wide bandwidth (upto 1.5 GHZ) and during this EMI injection, the protection diodes must be able to handle upto 100mA currents (well they do so, I mean the bias circuitry must). The tech I am using is a 0.18um high voltage technology. Supply voltage is 5V.
Thanks in advance
Thanks in advance
