cocopa
Junior Member level 2
Hello, I'm getting an analog output from an op amp (connected as an integrator) and i want to drive it to an oscilloscope via a BNC connector, and also use as an input to a peak detector, also utilized with op amps.
Is it necessary to use a buffer? And which is the best way to split and route the signal in the pcb?
Thanks in adnance!
Thanks in adnance!
