Best Programmer ? ? ?
zawminoo
best pic programmer
Hi every body,
What is the best programmer in market?
1.For microchip PIC.
2. For 8051 Series.
3. For EPROM
Please share your knowledge.
Thank!
Zaw
best pic programmers
There have been many post here regarding different programmer for different microcontroller.
Try to find which suites your needs.
Things to consider:
1. Microcontroller that you will use
2. Range or family of microcontroller
3. Budget
4. Availability of parts if you want to do it yourself
5. Software compatibility
6. Interface that you will use (ex. serial, parallel, usb)
I have done several PIC programmer like:
1. P16PRO - a parallel port programmer which is supported by vast numbers of programming software. Winpic offers wide range of supported MCU.
2. DIY K149 - Supports serial and usb interface (using ftdi usb to rs232 converter). The software is MicroPro.exe only. It has a pre-programmed MCU inside.
3. GTP-USB Lite - Which I did today. It uses a pre-programmed 18f2550 so it is directly connected to the usb port without any converter needed.
If you need more info I'll be willing to post it here later.
Happy programming!!
:D :D :D
micropro.exe download
Hi to all,
the best programmer for me is WILLEM programmer,
proffesional look and made, very cheep, very good software,
look on www.sivava.com,
regards
best pic programmer
For 8051 I use Asim Khan Programmer, it is fast, and easy, and of course it is free.
best parallel pic programmer
hi,
for programming PIC microcontrollers you can use MPLAB ICD2 and PICSTART PLUS
the best pic programmers
I have been using TopMax from eetools for years and it is just fine. It is a universal programmer and its software is continuously updated to add most recent parts.
www.eetools.com
eprom programmer - eetools:
PIC programmer is costlier I will advice you to use In Circuit Programmer
for pic go to www.bobblick.com programmer given is quite good n is easy to make if u dnt hate soldering ;)
