Best design for new processor+ Graphics card or chip
LegolasYiu
I was thinking of making a card that has processor (like Xeon E3 processor) with high performance graphics got GPGPU in one PCIe card design. Is that possible? How can I start designing it? This is for deep learning purposes.
At least for me it is not clear the end application of this board, for instance if it is also intended to perform general control of other stuffs or just graphics acceleration, but if you are considering to embeed both the Xeon CPU and the Nvidia GPU both working together you are certainly aware the most computing benchmarks show a similar performance, leastways within the same magnitude order.
Good point. I want to reduce bottlenecks for CPU and GPU communications.
I updated my design. Do you think it is better layout?
Your diagram is no much more than a scratch, in other words it is not a project illustration. For a system of this complexity would be expected the outline of an architecture in detail, or at least with more whim. Also, you did not inform the specifications of your project / application, as suggested earlier. Apparently, now you are considering working with both operated independently, not interconnected. I can not be expert in this, but I would have considered putting both the CPU and GPU on the same bus of the board, with no bridge. Had you considered both CPU/GPU within a single chip, either on hard or softcore ? Had you made researches on the capabilities of each alternatives to check which one better meets your requirements ? Anyway, as a good practice, to establish the requirements would be the first step before drawing up the project. Just an additional check: Did you really considered the power "bus" at the above general diagram, or is it a signal bus ? I am seriously beginning to doubt that you have actually been assigned to a task like this.
Thanks for the information. I will research on the capabilities of each alternatives. I think GPU+CPU integration will reduce latency even more. I consider the power bus a general diagram. I need to find out the requirement.
