Benefits of Wireless Networks
niro
Junior Member level 1
just good points please
Companies can realize the following benefits by implementing wireless networks:
• Mobility
• Ease of installation in difficult-to-wire areas
• Reduced installation time
• Increased reliability
• Long-term cost savings
Mobility
User mobility indicates constant physical movement of the person and their network appliance. Many jobs require workers to be mobile, such as inventory clerks, healthcare workers, policemen, emergency care specialists, and so on. Wireline networks require a physical tether between the user’s workstation and the network’s resources, which makes access to these resources impossible while roaming about the building or elsewhere. As an analogy, consider talking on a wired phone having a cord connecting the handset to the telephone base station. You can utilize the phone only within the length of its cord. With a wireless cellular phone, however, you can walk freely within your office, home, or even talk to someone while driving a car. Wireless networking offers mobility to its users much like the wireless phone, providing a constant connection to information on the network. This connection can be extremely useful if you are at a customer’s site discussing a new product, delivering emergency care to a crash victim, or in a hotel room sending and receiving e-mail. You cannot become mobile unless you eliminate the wire through the use of wireless networking.
Installation in Difficult-to-Wire Areas
The implementation of wireless networks offers many tangible cost savings when performing installations in difficult-to-wire areas. If rivers, freeways, or other obstacles separate buildings you want to connect (see fig. 1.8), a wireless MAN solution may be much more economical than installing physical cable or leasing communications circuits such as T1 service or 56 Kbps lines. Some organizations spend hundreds, thousands, or even millions of dollars to install physical links with nearby facilities. If you are facing this type of installation, consider wireless networking as an alternative. The deployment of wireless networking in these situations costs thousands of dollars, but will result in a definite cost savings in the long run.
Figure 1.8 A difficult-to-wire situation.
The asbestos found in older facilities is another problem that many organizations encounter. The inhalation of asbestos particles is extremely hazardous to your health; therefore, you must take great care when installing network cabling within these areas. When taking necessary precautions, the resulting cost of cable installations in these facilities can be prohibitive. Some organizations, for example, remove the asbestos, making it safe to install cabling. This process is very expensive because you must protect the building’s occupants from breathing the asbestos particles agitated during removal. The cost of removing asbestos covering just a few flights of stairs can be tens of thousands of dollars. Obviously, the advantage of wireless networking in asbestos-contaminated buildings is that you can avoid the asbestos removal process, resulting in tremendous cost savings.
In some cases, it might be impossible to install cabling. Some municipalities, for example, may restrict you from permanently modifying older facilities with historical value. This could limit the drilling of holes in walls during the installation of LAN cabling and network outlets. In this situation, a wireless LAN might be the only solution. Right-of-way restrictions within cities and counties may also block the digging of trenches in the ground to lay optical fiber for the interconnection of networked sites. Here, a wireless MAN or WAN might be the only alternative.
Reduced Installation Time
The installation of cabling is often a time-consuming activity. For LANs, installers must pull twisted-pair wires above the ceiling and drop cables through walls to network outlets that they must affix to the wall. These tasks can take days or weeks, depending on the size of the installation. The installation of optical fiber between buildings within the same geographical area consists of digging trenches to lay the fiber or pulling the fiber through an existing conduit. You might need weeks or possibly months to receive right-of-way approvals and dig through ground and asphalt. The deployment of wireless LANs, MANs, or WANs greatly reduces the need for cable installation, making the network available for use much sooner. Thus, many countries lacking a network infrastructure have turned to wireless networking as a method of providing connectivity among computers without the expense and time associated with installing physical media.
Increased Reliability
A problem inherent to wired networks is the downtime due to cable faults. Moisture erodes metallic conductors. These imperfect cable splices can cause signal reflections that result in unexplainable errors. The accidental cutting of cables can also bring a network down quickly. Water intrusion can also damage communications lines during storms. These problems interfere with the users’ ability to utilize network resources, causing havoc for network managers. The advantage of wireless networking, then, is experiencing fewer problems because less cable is used.
i thinks that the best is mobility
I think it's less time more savings 'n' mobility
Reduced Implementation Cost in Communication networks is the greatest advantage of Wireless networks.
I believe mobility is the most important of all. Take mobile phones, for an example. It is so successful.
Also, inter-working with other networks like the GSM technology is a additional advantage to the list.
wireless networks have some benefits but i think they also have weaknesses, the importance problem is security.
