omshankar
Junior Member level 1
My bridge rectifier(1N4007) is giving some voltage at ground terminal of bridge while measuring with the ground of oscilloscope at 220V 50 Hz power supply.....
I found a reason for this the breakdown voltage of diode is 120V.
dts y all diode conducting beyond d 220V and gives reverse voltage level at ground....
My Question is that
why all of the SMPS circuit use Bridge rectifier(1N5399) directly 220V ac with a single fuse? Does reverse voltage at ground not harm to the Capacitors?
What is the reason behind this?
My Question is that
