Baur rate of AT89S52
maniac84
Full Member level 6
Full Member level 6
Baut rate of AT89S52
Hi guys. Currently trying to figure out how to calculate the baud rate of my AT89S52 mcu.
From the data sheet (http://www.atmel.com/Images/doc4316.pdf), there's this formula to calculate the baud rate:
Then there's this table:
Is the table showing the BRL value which we can get from the formula?
I tried to use the formula given to calculate the BRL using Fosc=11.0592Mhz and 9600 baud rate, but I couldn't get the value from the table which is FDh. What I get is FAh. Why is it? Please help guys.
I'm trying to use the 9600 baud rate with a 20Mhz xtal. The value given in the table shows I must use F5h and the SMOD=1. But there's SMOD0 and SMOD1 registers. What is the value for SMOD0 and SMOD1 if SMOD=1?
SM0 = 0
SM1 = 1
:wink:
IanP
Reactions: DrWhoF
    DrWhoF
Why is it is SM0 and SM1 instead of SMOD0 and SMOD1?
Notation depends on teacher/book/school ..
SM0=SMOD0
SM1=SMOD1
for lazier people, less letters ...
:wink:
IanP
Reactions: DrWhoF
    DrWhoF
SM0=SMOD0
SM1=SMOD1
:wink:
IanP
Noted.
I want to use it in 9600 baud rate on timer 1. So, I put SCON = 80h and TH1=F5h. But it won't work.
When I try on 4800 baud rate which is SCON=00h and TH1=F5h. It work!
Do you guys know what's wrong?
Noted.
There is a confusion here; let’s explain it ---
SMOD is bit 7 of PCON register and when set to “0” {SMOD=0} divides 1/12 of the clock frequency by 32.
When set to “1” {SMOD=1} divides 1/12 of the clock frequency by 16.
This is still within the PCON register.
SM0 and SM1 are bits of the SCON register.
Don’t confuse SMOD with SMs …
As far as the setting for 9600bps goes, serial mode1 is set by SM0=o and SM1=1, that makes the SCON register set to #50h (with the REN bit also set to “1”), not #80h.
The TMOD register should be set to #20h …
And bit7 of PCON (SMOD) set to “1” …
9600= 2 x 20MHz /[32 x12 x (256-TH1)]
TH1 =10.8 --- closest 11--- 0xf5
Something like:
MOV A, PCON                                ;A P CON
SET B ACC.7                                 ;make D7 = 1
MOV PCON, A                                 ;SMOD = 1, double baud rate
MOV TMOD, #20 H                        ;Timer 1 mode 2, auto reload
MOV THI,#0F5 H
MOV SCON, #50 H
Now it should work …
:wink:
IanP
Reactions: DrWhoF
    DrWhoF
Something like:
MOV THI,#0F5 H
MOV SCON, #50 H
:wink:
IanP
I've tried your code but still don't work.
I try to use 4800 baud rate by only writing:
MOV TMOD, #20 H
MOV THI,#0F5 H
MOV SCON, #50 H
This worked.
But after adding your code to do 9600 baud rate:
MOV A, PCON
SET B ACC.7
MOV PCON, A
MOV TMOD, #20 H
MOV THI,#0F5 H
MOV SCON, #50 H
It won't work. Do you know what's wrong? What should I check again?
Is it that this mcu is not suitable to use 20Mhz xtal? This is because I search examples from websites and most of it uses 11.0592Mhz xtal.
