PAC8911
Newbie level 3
Hi!
I want to buy a charger for a lead acid battery of 12V and 7.5Ah. The charger must be connected to a power supply of 24V and I already have options. My problem is that I want to use the battery as backup connect to a circuit that needs 12V and 0.2A. I was thinking in connecting in parallel the charger, with the battery and my circuit but I don't know if this is possible.
I have read in some places and they say that the charger must think that the battery needs more energy and change from "maintenance mode to charging mode" and this would cause a overcharging. Is this right? I mean is just 0.2A? is there any solution?
Later I want to know if after the light comes back and the charger start charging the battery will send 2A, this would affect in some way my device?
I was thinking is use the Model 2544 of Mascot.co as charger.
The battery is a Ritar 1275 of 12V and 7.5ah.
I will connect some sensors and a Rabbit Board (both can work from a range of 9V to 18, so there is no problem with the 14.7V of the charger)
Thanks!
Thanks!
