Aug 22, 2011 #1 nouman_rafi Newbie level 5 Joined Aug 22, 2011 Messages 8 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location Pakistan Activity points 1,336 i need battery charging circuit of solar pannel 17.1 v.
Aug 22, 2011 #2 M moataz fouad Member level 1 Joined Sep 25, 2007 Messages 36 Helped 10 Reputation 20 Reaction score 10 Trophy points 1,288 Location Egypt Activity points 1,489 Dear Nouman, Have a look on the attached application note for your request. Hope it'll be useful. Best regards. Attachments LT3652.pdf 254 KB · Views: 115
Aug 23, 2011 #3 E ea.arun Full Member level 2 Joined Apr 26, 2011 Messages 123 Helped 33 Reputation 66 Reaction score 32 Trophy points 1,308 Location Chennai Activity points 1,942 shall try these too.... **broken link removed** http://cds.linear.com/docs/Demo Board Manual/dc1621af.pdf
Aug 23, 2011 #4 nouman_rafi Newbie level 5 Joined Aug 22, 2011 Messages 8 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location Pakistan Activity points 1,336 sir i need 3 amp battery charger.my solar pannel is 17.1 v....
Aug 23, 2011 #5 M moataz fouad Member level 1 Joined Sep 25, 2007 Messages 36 Helped 10 Reputation 20 Reaction score 10 Trophy points 1,288 Location Egypt Activity points 1,489 nouman_rafi said: sir i need 3 amp battery charger.my solar pannel is 17.1 v.... Click to expand... Kindly check the attached datasheet, it's upto 3A. Best regards. Attachments 1511fb.pdf 140.6 KB · Views: 99
Aug 23, 2011 #6 Raza Advanced Member level 3 Joined Feb 10, 2002 Messages 828 Helped 266 Reputation 530 Reaction score 259 Trophy points 1,353 Location PAK Activity points 4,486 Salam nauman, You specified the voltage of the Solar Panel but not the current capacity of the same? Sorry for querying is the panel capable of supplying 3 amperes? If yes look at the following you may get your answer in the application examples. LM338 pdf, LM338 description, LM338 datasheets, LM338 view ::: ALLDATASHEET ::: Further help questions welcomed.
Aug 23, 2011 #7 E ea.arun Full Member level 2 Joined Apr 26, 2011 Messages 123 Helped 33 Reputation 66 Reaction score 32 Trophy points 1,308 Location Chennai Activity points 1,942 with a slight modification you can try this one too from TI..... https://www.ti.com/lit/ds/symlink/bq24650.pdf
