Tahmid
Advanced Member level 6
- Joined
- Jun 17, 2008
- Messages
- 4,756
- Helped
- 1,798
- Reputation
- 3,588
- Reaction score
- 1,656
- Trophy points
- 1,413
- Location
- Berkeley, California
- Activity points
- 30,585
Check this link:
https://www.xantrex.com/power-products-support/faq.aspx
Go to "Battery Technology and Maintenance Overview".
"Lead acid battery technology has come a long way since 1859, the year it was invented. You no longer have to check the state of charge with a hygrometer, or top the batteries up with distilled water. Batteries are now safer, more reliable and in some cases, virtually maintenance free. Lead acid batteries are recommended for use with inverters because:
Hope this helps.
Tahmid.
- They are low cost, widely available and easy to manufacture
- They are durable and dependable when properly used and stored
- The self discharge rate is lower than that of other battery technologies
- There’s no memory effect
- They can produce a lot of current very fast, which is important in inverter applications.
Hope this helps.
Tahmid.
