kalkulator
Newbie level 3
- Joined
- Jan 30, 2015
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 33
Hello, have a simple question to ask you guys, because I dont have much experience in this field.
So I have two 12V fans (80mm) that need to be controlled remotely. I got myself a 2 channel wireless switch and two fans. The problem is that fans need to work on battery, and are quite strong, each is using about 0,5 amp and 12V. The battery will have to be as small as possible, and will have to be able to run fans for at least one hour, maybe a little less is acceptable too.
Is there anything you can recommend me?
Thanks.
Thanks.
