Lipton2
- Joined
- Jun 6, 2014
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 55
Hey!
I am trying to make a simple SPI connection with between a TC77 digital tempereture sensor and my PIC6f690.I have read all the datahseets very carefully and connected everything ok, but it doesn't seem to work..
When i try to read from the TC77 i need two INT, because it send a 13 bit signal. So i read the SSPBUF registers twice and then shift the registers to form one int. To check if the value is good, i send the output through UART to my PC with the pickit2 application. But when i check the temperature I only get the weird value of 73..
Can you please help me to find the problem?
#include <htc.h>
#include <pic16f690.h>
void initTMR0 (void);
void initUARTsend (void);
void initSPI (void);
signed int SPI_receive();
void UART_send(signed int temp_out);
void main()
initTMR0(); //TMR0 init
initUARTsend(); // UART init
initSPI();
signed int temp;
temp=0;
PORTC=0; // PORTC reset
while(1)
temp = SPI_receive();
__delay_ms(100);
UART_send(temp);
void initTMR0(void)
OPTION_REGbits.PS0=1; //Prescaler is divide by 256
OPTION_REGbits.PS1=1;
OPTION_REGbits.PS2=1;
OPTION_REGbits.PSA=0; //Timer Clock Source is from Prescaler
OPTION_REGbits.T0CS=0;//Prescaler gets clock from FCPU (1MHz)
INTCONbits.T0IE=1; //Enable TIMER0 Interrupt
INTCONbits.T0IF=0;
INTCONbits.PEIE=1; //Enable Peripheral Interrupt
INTCONbits.GIE=1; //Enable INTs globally
void initUARTsend(void)
SPBRG = 25; //Fosch 4Mhz -> baudrate 2400
TXSTAbits.BRGH = 0; //Sets Low Baud Rate
TXSTAbits.SYNC = 0; //Sets Asynchronous mode
RCSTAbits.SPEN = 1; //Enables EUSART
TXSTAbits.TXEN = 1; //Enables the EUSART transmiter
void initSPI(void)
TRISCbits.TRISC6=0; //CS SPI output
TRISCbits.TRISC7=0; //SDO SPI out
TRISBbits.TRISB6=0; //SCK out
TRISBbits.TRISB4=1; //SDI SPI IN
SSPCONbits.SSPEN = 1; //= Enables serial port and configures SCK, SDO and SDI as serial port pins
SSPCONbits.CKP = 1; //Idle state for clock is a low level (Microwire alternate)
SSPCONbits.SSPM = 0; //SPI Master mode, clock = FOSC/4
SSPSTATbits.SMP = 0; // Input data sampled at middle of data output time
SSPSTATbits.CKE = 1; //data transfer on rising edge clk
signed int temp_out_msb;
signed int temp_out_lsb;
signed int temp_out;
temp_out = 0;
PORTCbits.RC6 = 0; //CS laag, initieer communicatie
__delay_ms(10);
SSPBUF = 0; //dummy to start clk
//First 8 bits
while(!PIR1bits.SSPIF) //wait for receive complete
temp_out_msb = SSPBUF;
PIR1bits.SSPIF = 0;
//last 6 bits
SSPBUF = 0; // write dummy data again to initiate second receive
temp_out_lsb = SSPBUF;
PIR1bits.SSPIF = 0;
PORTCbits.RC6 = 1; //CS high, stop SPI
temp_out = ((temp_out_msb << 8 ) | (temp_out_lsb )); //shift bits to find temp
return temp_out;
while(!TRMT);
TXREG = temp_out; //Transmit the binary number 1x per se
