OOOPPPs
Newbie level 2
Im not sure if this is the right section, but i just want to ask for some information regarding the basic circuitry design. My Electrical Engineering skills are not flashy.
I want to essentially make a programmable microcontroler board (using ATmega64 series) which is connected to a bunch of IO devices (such as LCD/LED), but when I look at sample schematics, I find that there are resistors attached to certain ports of the microcontroller (ie. nearly all of the schematics have a Resistor connected to each pin of the I/O ports) and then some crazy capacitors at the reset & Vcc pins.
(**broken link removed**)
Is there a way I could find out how I should connect this?
Yes im pretty much starting from a very very very basic platform, so any info is good info heheh.
