Greetings... We are to establish basic communication between a PC and a Microcontroller using Visual Basic 6.0...
in our microcontroller program... once it received "1", "2", "A", or "B" it will transmit Strings to the PC that says...
"I Have received (1, 2, A or B)"
NOw we are trying it using VB 6.0...
here is our prgram...
Code Visual Basic - [expand] |
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
| Private Sub Command1_Click()
MSComm1.Output = Text1.Text [I]'send 1, 2, A, or B[/I]
End Sub
Private Sub Command2_Click()
End
End Sub
Private Sub Form_Load()
MSComm1.CommPort = 1
MSComm1.Settings = "9600, N, 8, 1" [I]'Port Settings[/I]
MSComm1.InputLen = 0
MSComm1.PortOpen = True
End Sub
'Now this is the problem we can't see the reply from the MCU... but we tried it in MikroC UART Terminal and its working... we're having problems in VB 6... what are the right codes to be used to make it work??
Private Sub MSComm1_OnComm()
If (MSComm1.CommEvent = comEvRecieve) Then
Text2.Text = Val(MSComm1.Input)
End If
End Sub |
