[SOLVED] Basic Help with ADC pic16f877
abmoncivais
Newbie level 2
Newbie level 2
Victoria de Durango, Mexico
Hi, i hope that someone can help me with a basic ADC program.
I'm trying to read 3 analogic pins in the portA, then the program have to compare the 3 inputs, and turn on a pin in the PORTB.
The action is for the lowest value in the portA
The program just turns on random leds in the portB
I'm using CCS and proteus, PIC16F877
#include <16F877A.h>
#device adc=10
#FUSES XT, NOWDT, NOPROTECT, PUT
#use delay (clock=4000000)
#BYTE TRISA=0X85
#BYTE PORTA=0X05
#BYTE PORTB=0X06
void main()
setup_adc_ports(ALL_ANALOG);
setup_adc(ADC_CLOCK_INTERNAL);
set_tris_b(0x00);
set_tris_a(0xFF);
while(1)
int16 x;
int16 y;
int16 z;
delay_ms(100);
set_adc_channel(0);
delay_ms(100);
x=read_adc();
delay_ms(100);
set_adc_channel(1);
delay_ms(100);
y=read_adc();
delay_ms(100);
set_adc_channel(3);
delay_ms(100);
z=read_adc();
delay_ms(100);
if (((x<y) && (x<z)))
PORTB=0b10000000;
delay_ms(100);
else
if (((y<x) && (y<z)))
PORTB=0b01000000;
delay_ms(100);
else
if(((z<x) && (z<y)))
PORTB=0b00100000;
delay_ms(100);
delay_ms(100);
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
PORTB=0b10000000;
delay_ms(100);
else if (((y<x) && (y<z)))
PORTB=0b01000000;
delay_ms(100);
else if(((z<x) && (z<y)))
PORTB=0b00100000;
delay_ms(100);
try this may work way you want
Thanks!
Actually, i used to have more things wrong in the code
This is my final code
#include <16f877a.h>
#device adc=10
#FUSES NOWDT //No Watch Dog Timer
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES PUT //Power Up Timer
#FUSES NOPROTECT //Code not protected from reading
#FUSES NODEBUG //No Debug mode for ICD
#FUSES NOBROWNOUT //No brownout reset
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD //No EE protection
#FUSES NOWRT //Program memory not write protected
#use delay(clock=8000000)
#byte PORTB = 0x06 //Definimos PORTB con la dirección del registro PORTB.
void main()
int16 x=0;
int16 y=0;
int16 z=0;
////Configuración///
setup_adc_ports(AN0_AN1_AN3);
//setup_pp(PMP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
setup_comparator(NC_NC_NC_NC);
// unsigned int16 tension=0;
//Variable para almacenar el valor de tensión leido por el ADC
//unsigned int8 valor; //Variable temporal.
set_tris_b(0x00); //0b0000000// Configuramos el puerto B como salida.
while(1){
set_adc_channel(0); //elegimos el canal que vamos a leer.
delay_us(10); // esperamos 10uS necesarios para el ADC
x=read_adc(); //Leemos la tensión en el canal que elegimos.
delay_us(10);
set_adc_channel(1);
delay_us(10);
y=read_adc();
delay_us(10);
set_adc_channel(3);
delay_us(10);
z=read_adc();
delay_ms(1); //Esperamos un poco.
//valor=tension/127;
//Calculamos a cuantos LEDs encendidos corresponde la tensión leida.
            PORTB=0b10000000;
            delay_ms(100);
            PORTB=0b01000000;
            delay_ms(100);
            PORTB=0b00100000;
            delay_ms(100);
