smitchell
Junior Member level 2
ethernet interface schematic
I've got a bit of a problem. I need to learn a lot about getting analog DC voltages onto ETHERNET really quick.
So far I understand that i have to convert my analog signal to digital, then feed it to a microcontroller. then I have to write code which will arrange this data to be passed on to an ethernet controller chip.
Can anyone recommend a certain microcontroller to use with a certain ethernet chip?
also, what format does a microcontroller need its input data in?
I am doing a project at uni where i need to monitor voltages in a circuit remoteley via ethernet, and currently i dont know much at all (as you can probably tell) I'm keen as mustard though, so I'd really appreciate all the help you guys can give me to get started
Thanks heaps,
Sam
Thanks heaps,
Sam
