shaswat
I have a very little doubt on the basics of a diode. After a small interval I found the answer but I don't know that I am correct or not. Here is where I stuck for 20 min
As diode starts conduction when the voltage across it is 0.7 volt (general condition). After studying piecewise linear model, the equivalent circuit of a diode can be replaced with the Ideal diode in series with the resistance and a threshold voltage 0.7 V.Now ,what is the meaning of that resistance??
I know as ideal diode is connected in series so resistance is responsible for the 0.7 v drop.
In practical if we consider a diode having forward current 10mA and forward voltage of 3.3V, then according to that model the average resistance(Rav) is
This results 260 Ohm. So is that 260 Ohm is responsible for the drop of 0.7V. I think, YES (correct me if I am wrong)
Now reverse of that, If I need a resistance of 260 ohm and instead of this if I connnect a diode, does it works as same as resistance (if V & I remains constant)???
Rav= (3.3-0.7)/(10mA-0)
