#define Enter 13
#define Plus '+'
#define Minus '−'
#define Multiply '∗'
#define Divide '/'
// This function sends carriage-return and line-feed to USART
void Newline()
Usart_Write(0x0D); // Send carriage-return
Usart_Write(0x0A); // Send line-feed
// This function sends a text to USART
void Text_To_Usart(unsigned char ∗m)
unsigned char i;
i = 0;
while(m[i] != 0)
{ // Send TEXT to USART
Usart_Write(m[i]);
i++;
// Start of MAIN program
void main()
unsigned char MyKey, i,j,kbd[5],op[12];
unsigned long Calc, Op1, Op2,Key;
unsigned char msg1[] = " CALCULATOR PROGRAM";
unsigned char msg2[] = " Enter First Number: ";
unsigned char msg3[]= "Enter Second Nummber: ";
unsigned char msg4[] = " Enter Operation: ";
unsigned char msg5[] = " Result = ";
// Configure the USART
Usart_Init(9600); // Baud=9600
// Program loop
for(;;) // Endless loop
MyKey = 0;
Op1 = 0;
Op2 = 0;
Newline(); // Send newline
Text_To_Usart(msg1); // Send TEXT
// Get the first number
Text_To_Usart(msg2); // Send TEXT to USART
do // Get first number
if(Usart_Data_Ready()) // If a character ready
MyKey = Usart_Read(); // Get a character
if(MyKey == Enter)break; // If ENTER key
Usart_Write(MyKey); // Echo the character
Key = MyKey - '0';
Op1 = 10∗Op1 + Key; // First number in Op1
}while(1);
Newline();
// Get the second character
Text_To_Usart(msg3); // Send TEXT to USART
do // Get second number
if(Mykey == Enter)break; // If ENTER key
Key = MyKey - '0';
Op2 = 10∗Op2 + Key; // Second number in Op2
}while(1);
Newline();
// Get the operation
Text_To_Usart(msg4);
do
Key = MyKey;
}while(1);
// Perform the operation
Newline();
switch(Key) // Calculate
case Plus:
Calc = Op1 + Op2; // If ADD
break;
case Minus:
Calc = Op1 - Op2; // If Subtract
break;
case Multiply:
Calc = Op1 ∗ Op2; // If Multiply
break;
case Divide:
Calc = Op1 / Op2; // If Divide
break;
LongToStr(Calc, op); // Convert to string
// Remove leading blanks
j=0;
for(i=0;i<=11;i++)
if(op[i] != ' ') // If a blank
kbd[j]=op[i];
j++;
Text_To_Usart(msg5);
for(i=0; i<j;i++)Usart_Write(kbd[i]); // Display result
