ismailov-e
Member level 1
Hi everybody!
I want to create a custom IP with axi-4 stream interface.
In Vivado 'create custom IP' it generated IP with blank verilog code with axi-4 stream protocol. During creation there was an option data depth 64 bytes(not adjustable). The code below:
But i did not see the buffer size. I guess i should by myself add register for buffers.
I see the data by 1 byte stored to "stream_data_fifo" total 32 bit (4byte) as data bus width.
Shoud i for every transfere shift "stream_data_fifo" to self created registers?
module myipp_v1_0_S00_AXIS #
// Users to add parameters here
// User parameters ends
// Do not modify the parameters beyond this line
// AXI4Stream sink: Data Width
parameter integer C_S_AXIS_TDATA_WIDTH = 32
// Users to add ports here
// User ports ends
// Do not modify the ports beyond this line
// AXI4Stream sink: Clock
input wire S_AXIS_ACLK,
// AXI4Stream sink: Reset
input wire S_AXIS_ARESETN,
// Ready to accept data in
output wire S_AXIS_TREADY,
// Data in
input wire [C_S_AXIS_TDATA_WIDTH-1 : 0] S_AXIS_TDATA,
// Byte qualifier
input wire [(C_S_AXIS_TDATA_WIDTH/8)-1 : 0] S_AXIS_TSTRB,
// Indicates boundary of last packet
input wire S_AXIS_TLAST,
// Data is in valid
input wire S_AXIS_TVALID
// function called clogb2 that returns an integer which has the
// value of the ceiling of the log base 2.
function integer clogb2 (input integer bit_depth);
begin
for(clogb2=0; bit_depth>0; clogb2=clogb2+1)
bit_depth = bit_depth >> 1;
end
endfunction
// Total number of input data.
localparam NUMBER_OF_INPUT_WORDS = 8;
// bit_num gives the minimum number of bits needed to address 'NUMBER_OF_INPUT_WORDS' size of FIFO.
localparam bit_num = clogb2(NUMBER_OF_INPUT_WORDS-1);
// Define the states of state machine
// The control state machine oversees the writing of input streaming data to the FIFO,
// and outputs the streaming data from the FIFO
parameter [1:0] IDLE = 1'b0, // This is the initial/idle state
WRITE_FIFO = 1'b1; // In this state FIFO is written with the
// input stream data S_AXIS_TDATA
wire axis_tready;
// State variable
reg mst_exec_state;
// FIFO implementation signals
genvar byte_index;
// FIFO write enable
wire fifo_wren;
// FIFO full flag
reg fifo_full_flag;
// FIFO write pointer
reg [bit_num-1:0] write_pointer;
// sink has accepted all the streaming data and stored in FIFO
reg writes_done;
// I/O Connections assignments
assign S_AXIS_TREADY = axis_tready;
// Control state machine implementation
always @(posedge S_AXIS_ACLK)
begin
if (!S_AXIS_ARESETN)
// Synchronous reset (active low)
begin
mst_exec_state <= IDLE;
end
else
case (mst_exec_state)
IDLE:
// The sink starts accepting tdata when
// there tvalid is asserted to mark the
// presence of valid streaming data
if (S_AXIS_TVALID)
begin
mst_exec_state <= WRITE_FIFO;
end
else
begin
end
WRITE_FIFO:
// When the sink has accepted all the streaming input data,
// the interface swiches functionality to a streaming master
if (writes_done)
begin
end
else
begin
// The sink accepts and stores tdata
// into FIFO
end
endcase
end
// AXI Streaming Sink
// The example design sink is always ready to accept the S_AXIS_TDATA until
// the FIFO is not filled with NUMBER_OF_INPUT_WORDS number of input words.
assign axis_tready = ((mst_exec_state == WRITE_FIFO) && (write_pointer <= NUMBER_OF_INPUT_WORDS-1));
always@(posedge S_AXIS_ACLK)
begin
if(!S_AXIS_ARESETN)
begin
write_pointer <= 0;
writes_done <= 1'b0;
end
else
if (write_pointer <= NUMBER_OF_INPUT_WORDS-1)
begin
if (fifo_wren)
begin
// write pointer is incremented after every write to the FIFO
// when FIFO write signal is enabled.
write_pointer <= write_pointer + 1;
end
if ((write_pointer == NUMBER_OF_INPUT_WORDS-1)|| S_AXIS_TLAST)
begin
// reads_done is asserted when NUMBER_OF_INPUT_WORDS numbers of streaming data
// has been written to the FIFO which is also marked by S_AXIS_TLAST(kept for optional usage).
writes_done <= 1'b1;
end
end
end
// FIFO write enable generation
assign fifo_wren = S_AXIS_TVALID && axis_tready;
// FIFO Implementation
generate
for(byte_index=0; byte_index<= (C_S_AXIS_TDATA_WIDTH/8-1); byte_index=byte_index+1)
begin:FIFO_GEN
reg [(C_S_AXIS_TDATA_WIDTH/4)-1:0] stream_data_fifo [0 : NUMBER_OF_INPUT_WORDS-1];
// Streaming input data is stored in FIFO
always @( posedge S_AXIS_ACLK )
begin
if (fifo_wren)// && S_AXIS_TSTRB[byte_index])
begin
stream_data_fifo[write_pointer] <= S_AXIS_TDATA[(byte_index*8+7) -: 8];
end
end
end
endgenerate
// Add user logic here
// User logic ends
endmodule
