When you say "Fail" what do you mean?
Are you using avrprog.exe from atmel?
Does the device read the signature bytes?
What device are you trying to program? It is possible that the firmware in your ISP programmer is outdated if you are trying to program any of the newer avr micros.
That programmer should work.
Some firmware loaded in the 2313 was changed around, MOSI and MISO lines were switched and a different baud rate was implemented.
So depending on what firmware you have in your programmer will determine whether or not it works for you.
If your board is exactly the same as in the link above, try this code in the 2313 on your board. If the hardware is working correctly, this code WILL WORK 100%!
