[SOLVED] AVR microcontroller delay problem
irfan ahmad
Full Member level 3
Full Member level 3
LAHORE PAKISTAN
I am trying to toggle PORTC of atmega16 at rate of
100ms.
this is my code .
#define F_CPU 8000000UL
#include <avr/io.h>
#include <util/delay.h>
int main(void)
  DDRC=0XFF;
  PORTC=0XFF;
  while(1)
  	 _delay_ms(100);
     PORTC=~PORTC;
  return 0;
these are simulation results on proteus.
it toggles after32ms.
Which pin are you measuring this on ? PORTC pins have many alternate functions, and there may be some conflict somewhere.
Try toggling just one bit, which is not too critical of its alternate functions.
i am measuring on C0.
if i am just toggling PORTC then i can measure from any pin.
am i right?
also i have tested this code
#include <avr/io.h>
int main(void)
  DDRC=0XFF;
  PORTC=0XFF;
  while(1)
  	 _delay_ms(250);
  	 _delay_ms(250);
  	 _delay_ms(250);
  	 _delay_ms(250);
  	 PORTC=~PORTC;
  return 0;
with these fuse settings L=0XE4 , H=0XF9.
using genius programmer G540
It is flashing led very fast. less then 250ms.
please guide me .
currently i am trying to enable internal oscillator at 8Mhz.
