AVR Gcc error Attiny13 - float value return to Uint16 - Error
thannara123
Advanced Member level 5
India
I am making a simple project with Attiny13
Trying to read ADC value while making program am getting Error as follows
Error 1 in extract_insn, at recog.c:2109
Error 2 unrecognizable insn:
It shows whenever i return the Unint16 value from a float value Pleas see the program .
#include <avr/io.h>
#include <avr/interrupt.h>
#define F_CPU 9600000
void adc_init()
	ADMUX=0x00; // VCC used as voltage referance
	ADMUX |= (1 << MUX0); //// Set the ADC input to PB2/ADC1
	ADCSRA |= (1 << ADPS1) | (1 << ADPS0) | (1 << ADEN);//Set the prescaler to clock/128 & enable ADC
unsigned int read_adc()
{   unsigned int LSB_data=0,MSB_data =0, adc_value=0;
	ADCSRA|=(1<<ADSC); // start conversion
	while(ADCSRA & (1<<ADSC));
	LSB_data = ADCL ;
	MSB_data = ADCH ;
	adc_value = ((unsigned int)MSB_data<<8);
	adc_value = adc_value |((unsigned int)LSB_data);
	return (adc_value);
int test()
 int i,adc_value[100]={0}; uint16_t temp =0;
 adc_init();
 for(i=0; i<100;i++)              // samples taking from 41 times 9.4milli second taken about on complte half cycle
	 adc_value[i] = read_adc();  // reading voltage
 temp = adc_value[0];
 for(i=0; i<100; i++)
	 if(temp<adc_value[i])
	temp=  adc_value[i];
// temp =100;
return (temp);//*(0.639)); //o making Peak to RMS
int main(void)
	 uint16_t adc_value1=0;
	adc_value1 = test();
	while(1)
        //TODO:: Please write your application code
<avr io.h=""><avr interrupt.h=""><adsc); start="" conversion
<adsc));
<adc_value[i])
The error will goes when i will give a random value to the variable temp just before the return in the test function.</adc_value)
</adsc));
</adsc);></avr></avr>
i posted the program but it shows a part only ?:oops:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
#include <avr io.h="">
#include <avr interrupt.h="">
void adc_init()
    ADCSRA|=(1<<adsc); start="" conversion
      while(ADCSRA & (1<<adsc));
    LSB_data = ADCL ;
    MSB_data = ADCH ;
    return (adc_value);
int test()
 adc_init();
    temp=  adc_value[i];
// temp =100;
int main(void)
    while(1)
It doesnt appear in CODE blocks
< /adc_value[i])
< /adsc));
< /adsc);>< /avr>< /avr>
Where's error line recog.c:2109? I guess not in the posted code.
sir above posted the full code .
We still can't see the full code and the image in post #5 is not part of the code previously shown.
I'm not sure what IDE you are using but to subtract 307 from an ADC result could produce a negative result and then multiplying it by a fraction may lose it altogether. Bear in mind you seem to be casting the result as an unsigned integer. I suspect you have mixed up the data types somewhere but without the full code it's difficult to see where.
Brian.
Post #3 has the full code
Sir, i am not completed the full code in main function .
The error came out while i complete these functions which is shown in psot #3.
me also think that " you said the data type problem ".But the same program i used and worked out in Atmega8
I am using atmel Studio (AVR gcc)
I put the whole code i Have written no Hidden program
Even if changed the code as shown below
return  temp;//( uint16_t)(temp-307)*.660;
But the same error persist .
is there any effect computer virus on compiler ?
Atmel studio doesn't work in Linux so I can't check it myself but you still have some suspicious type conversions.
For example: "read_adc()" returns an unsigned integer value but you then use "adc_value = read_adc();" where the adc_value[] array holds signed integer values. The compiler probably does promotion/demotion automatically but you could lose accuracy.
Another example: "test()" returns a signed integer result but you then use "adc_value1 = test();" where adc_value1 is an unsigned integer.
Brian.
