[AVR] AVR code not working on Atmel Studio 6
LeoStar
Member level 2
Member level 2
Hey there champions,
I am back with another jug of problems.
I have just started working on AVR Atmega16 microcontroller.
And I am using Atmel Studio 6.
I am very well familiar with the programming of PIC microcontroller on Microchip.
And i find it quite easy to build.
But i tried to program AVR in the same way of building logic as that of PIC and I it didn't work.
Here is the code that I tried.
PURPOSE OF CODE:
To on an LED with a Button for ten seconds
Here is the group of instructions that I wrote considering it complete code:
#include<avr/io.h>
#include<util/delay.h>
#define SW1 PA0
#define LED1 PA1
void main()
DDRA=0xFE;
PORTA=0x01;
LED1<<0;
while(1)
if(sW1==0)
LED1<<1;
_delay_ms(10000);
else
LED1<<0;
When I tried it on proteus, nothing happens no matter how many times i press the button.
Plus there is an error of internal exception on proteus and it crashes.
Any help would be greatly appreciated. It is urgent for me.
So please someone look for it.
Eagerly waiting for the reply.
Thanks in advance.
Hi, LeoStar
#define SW1 PA0  //pin must be input (PINA.0 in CVAVR)
#define LED1 PA1
void main()
DDRA=0xFE;
PORTA=0x01;
LED1<<0;   //no effect
while(1)
if(sW1==0)    //must be SW
LED1<<1;     //LED1=1; or LED1=1<<LED1
_delay_ms(10000);
else
LED1<<0;     //LED1=0; or LED1=0<<LED1
See if ADC has to be disabled to make the pins digital IO. For input PINA0 has to be used.
I don't use Atmel Studio much. I use mikroC PRO AVR Compiler. Here I am attaching a working project. You can test it in hardware. It is compiled for 4 MHz external oscillator.
I have tested this in Proteus and it works fine. You can download and install demo version of mikroC PRO AVR Compiler and open the .mcpav file.
  • LED and Switch.rar
Thank you so much for replying guys.
DeepOne i tried your way and got the following error:
Error 3 lvalue required as left operand of assignment
for the following line:
LED1=1<<LED1;
Please tell me how to resolve this.
And the pin is already configured as input pin(DDRA=0xFE;).
And Milan thanks for advicing regarding the ADC, I will disable them and try it once again.
And I don't want to quit working on Atmel Studio 6 as it is new for me and adds variety to my software list.
I will find some other way of programming but wont quit working on it.
I will set it as my last resort to work with MIKRO C PRO AVR.
Thanks a lot for your precious time guys.
Looking forward to hear from you soon again.
LED1=1<<LED1; //this equation is work in CVAVR, i think in #define LED1 PA1 - PA1 must be PORTA.1 or something equal
pin is already configured as input pin //of course, but it is necessary to address it as input register (PINA.0 in CVAVR)
// ADC is already disabled after power on reset, according to datasheet
seems construction like PORTA.1 or PINA.0 is not work in Atmel Studio. So you may use equation like PORTA |= 1<<PA1, if(PINA&PA0){do something}, etc. or manually organize access to separate bits. For example:
typedef unsigned int uint8_t;
typedef struct Bits_t
uint8_t Bit0 :1;
uint8_t Bit1 :1;
uint8_t Bit2 :1;
uint8_t Bit3 :1;
uint8_t Bit4 :1;
uint8_t Bit5 :1;
uint8_t Bit6 :1;
uint8_t Bit7 :1;
}Bits;
#define PortaBits (*((volatile Bits*)&PORTA))
#define PinaBits (*((volatile Bits*)&PINA))
#define LED1 PortaBits.Bit1
#define SW1 PinaBits.Bit0
void main()
DDRA=0xFE;
PORTA=0x01;
 while(1)
	if(SW1==0)
	LED1=1;
	_delay_ms(10000);
	else
	LED1=0;
Hello everyone,
Long time no see.
I have started working on MIKRO C PRO FOR AVR. I use it for pic as well and I consider it the best among the compilers.
Here is the code that i am trying on it. It gets compiled without errors but when i try it on proteus the pin that is connected to led is low and the pin with the switch is high as well but when I push the button it doesnt work.
Here is the code:
sbit SW1 at PinA.B0;
sbit LED at PORTa.B1;
void main()
DDRA=0xFE;
PORTA.B0=1;
if(!SW1)
LED=1;
delay_ms(5000);
else
LED=0;
And the attachment shows that the led doesn't glow even if the switch is pressed.
Any help will be appreciated.
And whenever I try it out on proteus there is an error and proteus crashes. I am attaching a snapshot of the error as well. PROTEUS ERROR.jpgAVR.jpg
Try this project. It toggles LED on button press and release.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
sbit SW at PINA.B0;
sbit LED at PORTA.B1;
void main() {
    DDRA = 0xFE;
    PORTA = 0x00;
    while(1) {
        if(!SW) {
           Delay_ms(50);
           if(!SW);
              LED = 1;
        else if(SW) {
             Delay_ms(50);
             if(SW)
               LED = 0;
broken link removed
  • Switch and LED.rar
Thank you for your reply Milan, my code worked on proteus as well and now I have learned programming for AVR as well. As i told before I was very comfortable working with MICRO C so I made it to work.
Thanks a lot for your precious time.
