AVR and 8051 ISP programmer
wakaka
Full Member level 4
Hi all, i'm looking for this type of programmer(serial), preferably ISP coz i need to build one which size is as small as possible. I would to know the software to download the .hex as well. Plz help, thanks........
memarian
Full Member level 5
Dear,
Check PONYPROG at:
Good Luck!
cancel
Full Member level 5
i used yaap for long time, avrdude is choice for present time ;0)
wakaka
Full Member level 4
thanx, but i needa simple serial programmer for both avr and 8051.....
memarian
Full Member level 5
DEAR,
I download this file before.In this file you can find programs needs to program
AT89S8252 through SPI (with serial port).You can use for AT89S5x & AT89S89xx.
With a little modifications i think you can use it for AVR.But you can't use it for
AT89Cxx series.
note : base url of this document :https://jelmer.vernstok.nl/publications/at89prog.pdf
Good Luck!
wakaka
Full Member level 4
cant get the programmer....
