Hi all,
I need information about burst write operation in avalon bfm. Below i mentioned the task which i am using.
In that burst_size is 3 and burst_count in each burst is 2.So totally 6 data transaction will happen.But In my case i am getting only three data transacation and
and address is also not incrementing(Adress is zero for all transaction).
Please if any one knows about the burst transaction in altera avalon bfm help me .
////////////////////////////////Task //////////////////////////////////////
task data_init(output bit[511:0] data [int]);
for(int i=0; i<6; i++)
data = {$random(), $random()};
endtask
task avalon_write ([34:0] addr, bit[511:0] data [int]);
// Construct the BFM request
`BFM.set_command_request(REQ_WRITE);
`BFM.set_command_idle(0, 0);
`BFM.set_command_init_latency(0);
`BFM.set_command_address(addr);
`BFM.set_command_burst_size(3);
`BFM.set_command_burst_count(2);
begin
`BFM.set_command_data(data, i);
`BFM.set_command_byte_enable(48'hffff_ffff_ffff,i);
end
// Queue the command
`BFM.push_command();
// Wait until the transaction has completed
while (`BFM.get_response_queue_size() != 1)
@(posedge `BFM.clk);
// Dequeue the response and discard
`BFM.pop_response();
endtask
bit[511:0] data[int];
initial
begin
data_init(wdata);
avalon_write('d0,wdata);
end
Thanks
Venkat
