yaminipanneer
Newbie level 3
hi friends,can u just list out what are the tools available to design ,simulate and analyze the antenna design
hi
1: CST MWS
2: Ansoft HFSS
are the best available tools.
I've tried version 3.3.0 of the professional version (not the free one). I was unimpressed. You often get very few parameters you can design for. For example, if you attempt to design a Yagi-Uda antenna, you can't set the impedance. It tells you:If you are new to antenna design, this could be useful:
Antenna Magus - Antenna Design Software
FEKO is a antenna design tool
Most important antenna design and analyze tool for the real antenna, not the simulated one, is for me a VNA.
So that is probably the most important tool, the analyzer I have in my head. After a day or two do I usually find that it was a less good judgement I did from start, but a simulation tool had not done a better job either, as it neither delivers better result then what the user is able to provide.
Of course, some tools provide optimisers, but as far as I'm aware, in full 3D EM simulation, the time to analyse a solution is just too slow, so they are of limited use.
Hello there,
I was asking if you can send me the antenna magus V3.3 file. It gonne help me in my project.
Thanks
There's a free version. The professional version is nearly 8000 Euros. You can download the free version.
Dave
I would not say Antenna Magus is a particularly simple program, or that anything like it was written decades ago. It is quite different to most other antenna related software I've seen before, although it is similar to the Antenna Design Kit, which is a free download if you have HFSS (which is expensive).Why do these relatively simple programs, written decades ago and fully amortized, cost so darned much????
