jbs87
Newbie level 6
At work, I have to program first the CPLD, then FPGA and finally load a bootlader and then WINDOWS CE onto a board. For the CPLDs, I use Xilinx Impact and for the FPGAs, I use Flashpro 3, for the bootloader I use a USB wriggler with the Macgraigor flash progammer, and finally for Windows CE, I use the hyperterminal. The process of programming each board is the same so I was wondering if there was some way I could run one file and it would run the rest of programs, doing the programming in sequence for me (maybe a .bat file, I'm not sure). Any help would be much appreciated.
Joshua
Joshua
