Attribute list - Primetime
ee1
Full Member level 2
Full Member level 2
anyone knows how can i get a full attribute list and a description of each attribute in PrimeTime?
[i have tried "man attributes" - it work on dc and icc but not pt...]
Regards,
yes, but it doest give a descrןption for each attribue...
then you can use
get_attributes
as far as i know this command gives the attribute value...
i want to get a list of attributes description...in general...
Sorry looks like I am not clear with respect to your question..
do you want to know the detail of attribute means if following are the attributes in your design .. then you need to know the meaning (explanation) of these attributes?
area
attr_s
ba_capacitance_max
ba_capacitance_min
ba_resistance_max
ba_resistance_min
base_name
full_name
net_resistance_max
net_resistance_min
object_class
pin_capacitance_max
pin_capacitance_min
total_capacitance_max
total_capacitance_min
wire_capacitance_max
wire_capacitance_min
Let me know if I understood clearly or not.
yes, i want to know the description of each attribute,
for example:
area - float - The area of a cell. If the cell is hierarchical, this includes net area.
this information can be found in solvnet under the name "object attributes"
but i want to get it through the primetime shell...
hope it is clear now..
