ATtiny 2313 programmer
diyora
Newbie level 1
attiny programmer
Hello Sir,
I work on one project in which i control stepper motor through PC parallel port.I done programming in turbo C.Now i want to control stepper motor through USB port insted of parallel port.
For that i used controller ic ATtiny 2313 is used. This ic is controller ic so programmer is also required. What programmer is used & in which language programming done? So, please give me an idea about this.I find one programmer for this ic using parallel port. After load program in ic ,i used this ic in USB2LPT circuit diagram for USB communication as i mention early my project.So, please give me an idea about this.
Thank you.
With Regards,
diyora
ctownsend
Advanced Member level 2
Canada
2313 programmer
diyora said:
Hello Sir,
this one supports the attiny2313:
hxxp://rocky.digikey.com/WebLib/Atmel/Web%20Photos/ATAVRISP2.jpg
or you can build your programmer. Do a google search for avrdude.
My preference is to program in assembly because all of the atmel avr software tools are free such as AVR studio which is also a great simulator, and the best thing is its free!
Others program in C, and use WinAvr compiler which is also free.
Good Luck
manish12
Advanced Member level 3
atiny programmer
check the asim khan programmer
it will support the most chips from avr family .
nandhu015
Advanced Member level 5
India
Программатор для 2313
If you are new to microcontroller and AVR try codevision compiler.
There are many parallel port programmer floating around the web.
Try searching STK200 Dongle.
Regards
Nandhu
