Attenuate 200v ac to 5v dc/ac
nup
Junior Member level 2
hello everyone,
my project is stand alone solar power system.
and i need to implement PID control on the inverter side for load regulation.
i am using a controller called dspace 1103.
the problem is i need to give the output voltage of the inverter as a feedback to the controller which will implement the pid control.
but it accepts a voltage range of only 10V. max.
so is there any way i can convert 200v output of inverter to 10v dc/ac input, with minimum losses.
don't wanna use a transformer.
hi
I think you can use diode bridge rectifier and resistive voltage divider without a problem , for low losses uses higher range resistors (10k range )
Do you need some galvanic isolation between inverter output and DSP controller ?
Have a look at switched-mode power supply design. It uses an opto-isolator to provide safe isolation between the high and low voltage sections of the feedback circuit and is more efficient than a linear power supply. You will require a tiny high-frequency transformer.
Hi Nup,
I am using a design close to your need for a industrial charger
Here his the LTSpice file if you want to change some parameters
  • Opto_200v_to_5v.zip
Thanks a lot for everyone replies.
yes an isolation will be good.
the opto isolater sounds a good method to provide the feed back.
thanks..
