ATMEL to PIC code converter ???
mutevaggil
Member level 3
Istanbul-TURKIYE
pic to atmel convertor
hi all.
i wonder, is there a software that can convert mc codes one to another?
i mean, for example, converting ATMEL codes to PIC ones or vice versa.
is it possible? if yes, how?
thanks in advance.
convert atmel code to pic
i dont think that such program will exist
atmel assembler to c converters
i dont think so .Because of architectural.But maybe with c it might be possible.
Hai
I havn't seen such one...
Even porting C porgram to PIC is not so easy
Nandhu
it is might be possible in high level languages but with small modifications
but in assembly i dont think so
I don't think it's possible even from c because pic use different library from that of atmel.
from the graph theory point of view is always possible to do that ..But from the comercial point of view i don't see a BIG NEED for it !
Intel used to provide that type of migrating tool from the 8051 to 80196 16 bit line of micros ..But there was a market strategy
there used to be a software at:
h**p://www.kanda-systems.com/
though I never used it, but recently its seems their website is not working you could try:
h**p://www.ipass.net/hammill/newavr.htm
i am always wandring about those people like you
are you so lazy to transfer the code your self
imho if such a software is avialable and you used thats mean you aren'gt embedded designer you are embedded lazy how use others work in other processor
if the program is in C then it is to convert ....... just change the bits and bytes assignments
I think that even if you get Atmel to PIC convertor , but you have to check I/O port of base MCU and modified MCU.
If you program in C you no need to use convertor, you just change port setting. And comply in Keil for Atmel, MPLAB for PIC.
But if you program in ASM I think you can use ASM to C convertor to get C code.
