atmel to PC serial problem
mnady
I have aproblem
i want to read in matlab data that transmetted from Atmel (AT89c51cc01))
code
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
HELLO.C
Copyright 1995-2005 Keil Software, Inc.
#include <REG52.H>                /* special function register declarations   */
                                  /* for the intended 8051 derivative         */
#include <stdio.h>                /* prototype declarations for I/O functions */
    #define    baudrate 9600
#ifdef MONITOR51                         /* Debugging with Monitor-51 needs   */
char code reserve [3] _at_ 0x23;         /* space for serial interrupt if     */
#endif                                   /* Stop Exection with Serial Intr.   */
                                         /* is enabled                        */
The main C function.  Program execution starts
here after stack initialization.
void main (void) {
Setup the serial port for 1200 baud at 16MHz.
#ifndef MONITOR51
    SCON  = 0x50;               /* SCON: mode 1, 8-bit UART, enable rcvr      */
    TMOD |= 0x20;               /* TMOD: timer 1, mode 2, 8-bit reload        */
    TH1   = 221;                /* TH1:  reload value for 1200 baud @ 16MHz   */
    TR1   = 1;                  /* TR1:  timer 1 run                          */
    TI    = 1;                  /* TI:   set TI to send first char of UART    */
#endif
Note that an embedded program never exits (because
there is no operating system to return to).  It
must loop and execute forever.
  while (1) {
    P1 ^= 0x01;                 /* Toggle P1.0 each time we print */
    printf ("Hello World\n");   /* Print "Hello World" */
in matlab
the code
s = serial('COM1','BaudRate',9600);
fopen(s)
ss=fgets(s)
but the result in matlab is
Warning: The input buffer was filled before the Terminator was reached.
ss =
please help me to solve this problem
