Atmel 89c52 interfacing with AT24c512 EEPROM
imranahmed
Advanced Member level 3
Karachi,Pakistan
I WANT TO KNOW THAT I WROTE A CODE SAVING COUNTER VALUES IN EEPROM AT24c512 BUT PROBLEM IS THAT I COULD NOT ABLE TO STORE VALUE ABOVE 255, I WANT TO STORE VALUE 0-500.
PLEASE LET ME KNOW HOW TO DO?
void ex0_isr (void) interrupt 0
ex0_isr_counter++;   // Increment the count by button
void main()
ex0_isr_counter = read_byte_from_eeprom(0);
while(1)
write_byte_to_eeprom(0 , ex0_isr_counter);
display(ex0_isr_counter);
For sure you know that one byte has a limited range of 0...255 (unsigned).
This really is very basic knowledge.
--> use two or more bytes.
Klaus
Yes I know, counter value increases 0 to 500 when reaches 255 it got stored but above values are not storing?
I want to know how store values above 255?
Your
ex0_isr_counter
should be of int type
and the new code should be
write_byte_to_eeprom(0 , (ex0_isr_counter & 0xFF));
write_byte_to_eeprom(1 , ((ex0_isr_counter & 0xFF00) >> 8));
Yes it is already integer type but you provide best solution.Its great, you are good.
